AICC_TIME* Usage... How to use - HELP
Personally, I only do SCORM 1.2 at the moment. It's hard to say what's happening in LEARN.COM, as many LMS's work different. It is possible that the report is not calling on the right table, I mean, in docent, the coulum that has the time saved is not named AICC_score or anything like it. You may need to have the data base checked by user, course ID, and then look for the time to get it set up.I know you do not have to start the variable to have it keep track of the time. The initail value is always 00:00:00. I am not sure if you can change it. It is possible if you change the value, it will just fix itself when you go to the next page.What exactly are you trying to do with the value?
