AICC_TIME* Usage... How to use - HELP
This is a SCORM variable that is present if you show it or not...Even if you don't use the variable in the course, it is being recorded most likely in a database somewhere on your LMS. I use Docent 6.5 and I can go though the database and pull the time in a course fairly easy.To answer the other question, the variable is saved when you leave and continues when you come back. If you leave a course 00:20:00 in, you will come back into it at the same time. You could set a variable to mark a course as complete when time equals 01:00:00 or something like that.
