ADL Test Suite gives errors
I am trying to get my course into BlackBoard via SCORM. It does not work. Also I tested the SCORM package with the ADL suite and got lost of errors on the manifest test. Does anybody know I should move forward?many thx & regards,Jeroenps: here are a few first lines in the test report: ERROR: General Schema Error: Can't get back Schema document's root element :imsmd_rootv1p2p1.xsd. ERROR: General Schema Error: Can't get back Schema document's root element :adlcp_rootv1p2.xsd. ERROR: General Schema Error: Can't get back Schema document's root element :imscp_rootv1p1p2.xsd. ERROR: General Schema Error: Grammar with uri: http://www.imsproject.org/xsd/imscp_rootv1p1p2 , can not be found; schema namespace may be wrong: Xerces supports schemas from the "http://www.w3.org/2001/XMLSchema" namespace or the instance document's namespace may not match the targetNamespace of the schema. ERROR: Element type "manifest" must be declared. ERROR: Element type "organizations" must be declared. ERROR: Element type "organization" must be declared. ERROR: Element type "title" must be declared. ERROR: Element type "item" must be declared. ERROR: Element type "title" must be declared. ERROR: General Schema Error: Grammar with uri: http://www.adlnet.org/xsd/adlcp_rootv1p2 , can not be found; schema namespace may be wrong: Xerces supports schemas from the "http://www.w3.org/2001/XMLSchema" namespace or the instance document's namespace may not match the targetNamespace of the schema. ERROR: Element type "adlcp:masteryscore" must be declared.Edited By: jeroenb on 2008-4-3 3:21:21
