Trying to recover a problem .awt
January 25, 2010 12:00 AM
This happens when the autosave is interrupted. (most often in a network situation, where saving to the network). The only way to get it back is to revert to an earlier version in your backups, or redo it.
To prevent this from happening work locally, or turn off autosave when working over the network. I also always check to see if the autosave file and the working file are near the same file size. (the autosave looks like this in the folder ~Titlename.awt)
