transparency with images and png issues
Hi,
You may use IE5+ pngfix here : http://www.twinhelix.com/test/iepngfix.zip
1/ Making an Object type Top of file scripting with this following script, on the root of the course :
2/ Adding to the root of the course the 2 files previously dowloaded (iepngfix_tilebg.js and iepngfix.htc). These files will be copied in a new folder called automatically 'extern' at the root of the lectora course folder. After an HTML publication, these srcipts will be included to the HTML files.
3/ Testing whith IE5.5 or more.
