Test Problems
January 16, 2010 12:00 AM
1. For the student name, you need an action to show the name. On the Student Name text box on the Test Results page, add an On Show action to Change Contents; Target: Student Name; New Contents: name.
2. Progress bar - You should be able to change the type to Table of Contents and remove the action attached to it. This works if you do NOT randomize the test. However there seems to be a bug in Lectora if you do both of these so instead, leave it as it, change the range to 5 and change the attached action to Set Progress and in the Position field enter VAR(PageInChapter)
3. Are you aware that you are setting the AICC_Lesson_Status to complete on EVERY page of the test? You might want to move that action from the test level to the After The Test chapter.
