Questions and audio
June 16, 2005 12:00 AM
Set up one audio icon (name: Audio)On each clickable object add the following:Action:Name: Set audioON: ShowAction: Change ContentsTarget: Audio icon name (Audio)New Contents: Action:Name: Play AudioOn: ShowAction: PLayTarget: Audio icon name (Audio)This should reset the audio contents in the audio icon, and play the new one. As you are using the same icon, you should hear the new audio.
