Print Problems
 Thanks Ben for taking a look. The way the test result page is configured is to only display the Student name, test score, date, course name, "Passed" or "Failed" and the certificate message after the print and continue buttons. I have turned off everthing else by unchecking the boxes. Yes, you are correct the score will only print when published to the LMS and executed and it displays properly with a score however it just will not print out correctly. I will change the score varable because it is just one test. I have a multitude of problems modifying the code to get it to do a certian thing. Your suggestion of having 2 seperate pages is one that I was orginally going to implement however, I thought I would try what Lectora has built in first. Maybe that wasn't a good idea, one thing I came across is that after Lectora creates the code for the certificate it does not create an exit or continue button so I created an exit button to exit the screen after it prints otherwise there is no means to continue.
omacron77 said:
I have a test result and Certificate page that is displayed and can be printed after the test. Both displays OK however, when they print there is problems. The test results page is blank in "Portrait" (default) mode and only half of the data prints out in "Landscape" mode. The certificate only prints half of the image or data. The test results page is generated by Lectora when selecting "customized test results" in the properties section of the Test and the certificate is created using the certificate wizard in Lectora. From what I can see there is no control I have on page adjustment prior to printing except on the printer itself. Has anyone else ran into this problem? Does anyone have a solution on how I can get these items to print out correctly? I will post the test in the files section for viewing under the name Printing Problems, it will be in Zip format.
