Print Problems
January 28, 2010 12:00 AM
I looked at the file and it does have problems. For some reason it looks like all the feedback has been deleted when the Results page shows. Do you want feedback for each question on the Results page? None showed on the screen. When I printed I got 110 pages??? If you just want to show the % and give some other text, one way I know works is to have two pages in the After Test Chapter, one for passed and one for failed. Set them up the way you want. Set special Next buttons on those pages to go where you want them to go (Certificate page or Exit the course). If you want the individual question feedback, looks like something has gone south and I would try again. I have had difficulty modifying that page. It is not easy. It looks like all the stuff you add needs to go at the top for some reason. At least it did when I tried to modify it.
On the Certificate page, the score will not show until you are in an LMS environment if you use AICC_Score. This is the combined score of ALL the tests (if you have more than one). If you have only one test you can use testName_Score to set the score and it will work when published to HTML.
