Passing variable from Flash to Lectora 6
I'm not sure why that would matter... Have you gotten it to work with the html version? If so, what errors do you get when you generate the exe? As long as you are not targeting specific HTML page names in flash, I see no reason why it wouldn't work.I'm not sure why that would matter... Have you gotten it to work with the html version? If so, what errors do you get when you generate the exe? As long as you are not targeting specific HTML page names in flash, I see no reason why it wouldn't work.
