Using xml to populate Flash for Lectora
November 2, 2007 12:00 AM
Attach the xml file at the title level. Add the animation to your title and set a parameter to point to the XML file. Then you will probably have to publish to HTML or SCORM and manually put the folder with your images and actionscript (how are you calling actionscript from a separate folder?) in there. It can be done but you will have to make sure you are getting things in the right place rather than letting Lectora handle that for you. Attach the xml file at the title level. Add the animation to your title and set a parameter to point to the XML file. Then you will probably have to publish to HTML or SCORM and manually put the folder with your images and actionscript (how are you calling actionscript from a separate folder?) in there. It can be done but you will have to make sure you are getting things in the right place rather than letting Lectora handle that for you.
