Resize a project.
Do you mean change the page size for all pages? If so, yes. Create a new title and import all the pages using the Tools menu > Import command. Usually this will adjust the location of most objects. You will have to go thru every page and check to be sure they are all within the page boundry. If it were me, I would not let Lectora do it. I would Create new page guides at the outer edges of my new size in a COPY of your existing title. BE SURE TO COPY YOUR TITLE FIRST. Then manually move objects on each page to where they look right and are within the boundries. Then change the page size in the current title.
