Using xml to populate Flash for Lectora
November 2, 2007 12:00 AM
If you update it you have to re-attach it. That will replace the old one, OR you can just update the version in the Lectora created "extern" folder. That is where it will be copied to so it is included when you publish.If you update it you have to re-attach it. That will replace the old one, OR you can just update the version in the Lectora created "extern" folder. That is where it will be copied to so it is included when you publish.
