Using xml to populate Flash for Lectora
November 2, 2007 12:00 AM
Hi,I am also new to Lectora and ran into an issue with having XML work through Flash in Lectora. I have been able to get everything to work in preview mode inside of Lectora but the XML will not work when I attempt to publish the file. I have followed both of your suggestions (using the "Additional File" at the title level and adding the "Parameters" to the animation. Any other suggestions?
