Lectora 2009 problem?
January 22, 2009 12:00 AM
I can only address the popup part, un-check the Web 2.0 option when you publish your program and that should take away your scroll bar; that is if you are publishing as an HTML.Since I can't use Flash where I work; I can't address your flash issue. Sorry.
