I'm trying to hide an initially visible text block on mouse click, but...
June 7, 2013 12:00 AM
I'm trying to hide an initially visible text block on mouse click — but don't want it reappearing when you visit the page again. Anyone know how to do this?
Thanks
Jawad
First you'll want to create a custom variable in the Variable Manager. You can name the variable something meaningful and easy to remember, like "texthidden".
Then add a 2nd action to the button to Modify the Variable "texthidden" and set the value equal to "yes".
On Click > Modify Variable > Target: texthidden > Type: Set Equal To > Value: yes
Finally, add one last action to the page hide the Text Block IF texthidden = yes. You can set this using a condition.
On Show > Hide > Text Block > Condition - Variable: texthidden, Relationship: is equal to, Value: yes
I would combine it with an variable.
Try the following:
- Do not use initially visible
- Create an action that runs on showing the page, that shows the picture
- Set a condition to this action, that only shows the picture, when the variable 'whatever' is set to 0
- when clicking on the button, set the variable 'whatever' to 1 and hide the picture
Should work fine... :-)
