Help to execute idea!
I’ll try to explain this as clear as possible – I’ve attached a jpeg image as a reference/diagram too, and will assume you have viewed this first.
Text box “0” will be on the page initially visible, the two green “UP/DOWN” arrows also initially visible. By clicking the “DOWN” arrow I would want new text boxes to appear in a descending order, and by clicking the “UP” arrow to hide those ‘new’ text boxes in an ascending sequence.
Whether or not this can be done in Lectora is beyond me.
@AndyKing 47914 wrote:
When you say 'ascending' and 'descending' order, do you want box 1 then box 2 to appear? Then when rolling up, have box 2 disappear then box 1?
If so, the easiest way would be to add 2 actions to the graphic: 'on click > show > text box 1' and 'on click > show > text box 2' Add a small delay for text box 2.
Then you'd reverse it for the other button. 'on click > hide > text box 2' and 'on click > hide > text box 1' with a small delay on box 2.
If you wanted them to slide out, you could try using the 'on click > move to' option, Position the text boxes 1 and 2 under text box 0, then use the move to command to specify their X/Y position below. And again, the opposite for rolling them up.
hope that helps.
That's correct when you say 'ascending' and 'descending' order. However I perhaps should have mentioned, I don't want all boxes to appear one-by-one from a single click of the 'down' arrow. I want each individual box to appear after a 'click' of the down arrow.
Example: one click to show box '1', a second click to show box '2' etc. And in reverse for the 'up' arrow.
After I tested and typed this out, I realized you might have more than 3 text boxes, but hopefully this will get you started. You might just have to replace the condition/else actions with multiple actions. I don't have time today to test that out, but it should just be a matter of incrementing the variable, checking for what that variable is, and showing (or hiding) the appropriate text box.
oh ok.
still do-able.
So I tested it out and here's what I came up with, there may be another way to do this. I'm going to go with the boxes just appearing.
Create a variable called var_textboxes and set the default value to 1.
Set text box 1 and 2 to not be visible
On the "down" arrow, add two actions (in this order):
First action:
On: Mouse Click
Action: Show
Target: TextBox 1
Condition:
var_textboxes equal to 1
Else:
Show
TextBox 2
Second action:
On: Mouse Click
Action: Modify Variable
Target:var_textboxes
Value: 2
Modification type: Set Variable Contents
Condition:
Else:
Target: var_textboxes
Value: 3
Modification type: Set Variable contents
On the 'up' arrow (you're basically doing the reverse)
First action:
On: Mouse Click
Action: Hide
Target: Textbox 2
Condition:
var_textboxes equal to 3
Else:
Hide
TextBox 1
Second action:
On: Mouse Click
Value: 2
Condition:
Else:
Value: 1
Hope that helps.
Cheers Andy!
That's exactly what I wanted, if it's not to much trouble could you give me an example - if I were to add a third text box. I'm still trying to get my head around the process of what you did and how it worked.
Regards
Jawad
