Help with 'Entry Field' simulation
I would like to create a simulation using an Entry field, but I'm not sure how to pull it off.
I would want the user to type either "Train1" or "train1" into the entry field. Only if either value is met I would want to 'show' some text/image or maybe a button.
Can anyone help with this issue?
