Hot Spots and Mouse-Over
I know I can designate the Mouse Enter action on an image to pop up another object, such as a text box, and then the textbox will disappear when the cursor leaves the image area.
Is there a way to set up hot spots on a large image (like a screenshot) so that the same effect can be had? I create the hot spot with the text box, and put the show action to it, but I really don't want to have to click to show all of the elements because I would also have to "Hide" the rest of the elements for each action, and there are about 10. The programming can be quite cumbersome.
I tried to save the text box hot spot as a library object, but that didn't work. It would be so much simpler if Lectora simply included "MouseEnter" as one of the action options, as it does with image action options.
