Help with Menu - Prevent users from going to Final Assessment
May 27, 2013 12:00 AM
Good morning,
I've added a drop down menu (selected it from the Insert Menu) allowing learners to go to whatever lesson in the WBT they desire. However, I do not want them to have the ability to go to the Final Assessment without completing all the lessons. Would like to see some kind of pop up saying, you have not completed all the lessons....something like that.
Right now, if I use the menu option, learners can click on the last page of Lesson 6, then go to the Final Assessment. Complete the test...all within a matter of seconds....Is there a way for me to prevent this from happening. I really want to use the menu.
Can anyone help me.....Is there something on e-proficiency website that can purchase help me with this?
Appreciate any help you can provide.
Regards,
TMAC
Discussion (2)
On that last page in Chap 6, replace the standard Go to Next Page action button with a conditional action:
IF allchapterscompleted CONTAINS "a" & CONTAINS "b" & CONTAINS "c" & CONTAINS "d" & CONTAINS "e" & CONTAINS "f" THEN Go to Next Page ELSE Show Popup.
Of course, you'll have to create a custom variable called allchapterscompleted and add a letter to it each time the user completes one of the chapters.
