Audio Controller
Hi,
I'm adding audio to my web-based training and want to use the default controller however, the colour is dull and I would like to have something much brighter. Is it possible to download another controller, does anything else exist in Lectora. I don't have a lot of experience with flash or other products and was hoping there is another option available out there.
Any ideas.
Thanks for your time.
Regards,
TMAC
Discussion (4)
Select your audio, go to Properties, choose Controller. Lots of bright shiny skins there.
Hi got it...thanks so much.
Tmac
2 questions:
  • Apart from the available controllers, is there any online repository of more skins and themes from where we can download more options?
  • There is an option to manage custom skins. If we go in, it asks to locate a zip file. If we have to modify an existing skin, where will that be?
Thanks!
Lectora uses JW Player skins. You should be able to find many different sites for this by performing a simple Google search.
To modify existing skins, please follow timk's suggestion on this thread:
http://lectora.com/forum/showthread.php?t=11164
