Flash 8 Preloader not working in IE 7
Well, I checked my publish settings and it was set to Flash Player 7 and AS2, (which for reasons I wont go into were changed a while back for something else). So I reset my pub settings to use Player 8 and AS2.No difference.Again Firefox plays my preloader perfectly whereas IE7 does not. IE7 downloads the whole file and only after that begins to play the swf file.When I do a simulate download with my player settings set to slow Dial Up speeds, the results are also the same. Why is that?I'm trying to view across a corporate network from a remote location. Like I said Firefox displays the preloader perfectly, IE7 does not.I'm wondering if maybe my IT dept has set certain download settings for IE7 so that it doesn't stream. Could that be it?
