feedback for Drag and Drop and Matching
Well that is the way I interpret them. When you create the D&D, you create pairs. The first drag item is 1-1, the second is 2-2, the third is 3-3. So a correct answer is 1-1,2-2,3-3. If you move drag item 1 to drop position 2, it records 1-2.See my other post in the forum for references to a toolkit that you can view on line before downloading. One page on questions shows what is returned in each of the question variables. Check it out.More: What I do for the drag and drops and matching feedback ON THAT PAGE is to show the correct answer with an overlay for the D&D or orange lines for the matching. I have no solution for the Results page as a general solution. I hear that they will have an editable Results page in the next release but you would still have to go in and add whatever made sense. Edited By: bpitman on 2006-10-27 17:18:54
