Events in Audio file not showing correctly
January 15, 2010 12:00 AM
Well, after much hair pulling, I got it figured out. I had 3 different audio files on the page that played at different times- all with events. It turns out that each separate audio file had to have the event named different. In all 3 audio files, the events were named the same (event 1, event 2, etc.) So after changing the event names in each file, it worked fine.
Thanks!
falcon44nkc said:Hello. I have an audio .wma file that I have added events to. Event 1 shows a group of text and images, Event 2 shows a group of text and images and Event 3 shows two links. When one of these links are clicked, new audio, text and images appears. This works perfectly in preview mode. However, in browser mode and when I publish, it isn’t working right. Text appears at each 3 events, but it is the wrong text. It is the text that isn’t suppose to appear until after one of the links are clicked. I’m using Lectora X. Any ideas? THANKS!
More From Charity
Completed Status Doesn't retain if return to course after completing
October 7, 2009 Reply 0 UpvotesCompleted Status Doesn't retain if return to course after completing
