Drag and drop images don';t seem to work on Android
I have some test and quiz questions that have drag and drop images, but as we try to incorporate m-learning I've discovered they don't work on Android tablets and phones. Does anyone have a solution? This is a major flaw as drag and drop is a great learning tool. Drag and drop text blocks work, but not images. And no, I already tried putting an image in the text block and that just ceases to work on all devices.
Discussion (7)
@rwalters - Do you have anything in the Item Text field?
Can you zip and share your files?
I initially had nothing in the item text field. I tried adding text, but neither the text nor the images could be moved when viewed on an android device.
@rwalters - I was able to create a quick test for this issue and I am unable to replicate this error that you seem to be encountering. You can test this here: http://cloud.scorm.com/sc/InvitationConfirmEmail?publicInvitationId=fd1ab85e-3fb9-4faf-893e-f2604ddbc875
undefined Zip.
Thanks @eharris6433!
I'm going to bring this post to Support's attention and see if they've ran into similar issues. Unfortunately I don't have a Android device to test.
I'll email support about my courses, but the example above did not work for me on an android phone. It worked fine on a desktop.
