Display Message behavior not compatible with navigation
July 22, 2011 12:00 AM
I'm using the Lectora action called "Display Message" to activate when the user leaves the page. So if the user clicks the back or next button, a message pops up. Unfortunately, the message is only readable for a split second because the navigation kicks in and moves the user to another page thereby closing the popup. This popup, which I mentioned is a default action, has an OK button so this tells me that the popup should not close unless the user clicks the OK button.
Has anyone used the Display Message action and is there a way to keep the message visible until the user actually closes it?
