Creating Flash Audio
February 7, 2008 12:00 AM
I've created some flash audio files, and I want only a certain one to play on each page based on the value of a variable. Of course, preview mode always works correctly through its rose colored rendering engine. However, I run into problems in browsers. In Flash if I use a single frame for both the audio and a stop() command, the flash audios all play together and ignore the lectora actions even though I have autoplay disabled.To counter this I put the audio on a 2nd frame, and put a stop() command on each frame. This works in IE6, but not FF2. Really odd! How can I create flash audio to only begin playing when I want it to within Lectora???
