Creating Flash Audio
I don't know how to use native flash so my experience with flash audio is purely from having mp3s converted to swfs. In my experience the flash audio will play if it is initially visible, whether or not autostart is checked. Make all flash initially invisible then show the file if the variable is correct. I believe I've had actions to first show the file, then play the file. Some combination of this should work, but I'm sure others will have a better explanation of how to do it with native flash.Russ
