Creating Flash Audio
Why not do both:) You should be able to consistently load your MP3 using a Flash play mechanism. The trick is in getting things in the right place so you can bring them in at the right time. Adding your MP3's through the Additional files tab, by hitting properties on a root node right-click will drop all of your MP3s into the main course folder on publish. Your SWF's will be placed in an images subfolder. Your relative reference will be '..' when coded into your Flash piece.By feeding an MP3 filename into an SWF coded to play your audio, you'll be able to leverage the same player SWF on separate pages and you should get consistent playback on all platforms. And just say no to WAV's...
