Captivate SWF and Skins Issues
You need to make sure that the client has checked the box when publishing the captivate files to include the playback controls.If they are doing it correctly, another thing you want to check is see if all the skins are being linked properly. Run the swf files outside of lectora and see if they show up properly.You need to link to them as additional files in the title. That should help out with the skins.As for the main content, just import the main SWF as an animation then they should work ok.
