Test Completion Problem
July 28, 2008 12:00 AM
As Keith mentioned, you could place them in two separate AUs or if you are not concerned about the other test being included in the overall score and you do not want any of the interaction data from that test, go into the other test properties and under the results tab, deselect the option that refers to the test being included in the overall score. That way the LMS will treat the course as only having one true test in the title to capture results from.As Keith mentioned, you could place them in two separate AUs or if you are not concerned about the other test being included in the overall score and you do not want any of the interaction data from that test, go into the other test properties and under the results tab, deselect the option that refers to the test being included in the overall score. That way the LMS will treat the course as only having one true test in the title to capture results from.
