Captivate SWF and Skins Issues
August 6, 2008 12:00 AM
Rakenyon, unfortunately i don't know how to fix your problem. Executable is different than the HTML publishing than I am used to. My guess is that the files aren't linking properly in the EXE.Dezin, it will only work when publishing to html/scorm/aicc. When you do a preview in lectora, it will not show external references. Remove the external HTML object. Then in the properties of the awt file add the skin as an additional file. This way when you publish, the SWF file will know where to look which is in the root directory.
