Test Completion Problem
Hi Everyone - I'm having the darnest time with this course. I have Lectora 6 running on SumTotal LMS. Out of a 10 question test, I answered 8 correctly. The weight is set to 10 points per question. The test mastery is set at 80% both in the test results and AU. The max score for the AU is set for 100. When I took the test on the LMS I received a passing score of 80%, the correct results page displayed but when I refreshed the LMS the score said 40 and I received an incomplete status. Any ideas on how the LMS is calculating the score and/or what I need to do to fix the problem?Thanks,Traci
