Test Completion Problem
July 28, 2008 12:00 AM
Do you have more than 1 test in your title? It sounds like their are two tests and you only took one of them. With SCORM, it always bases the score of all the tests out of 100 so if you got an 80% on one test and nothing on the second, a value of 40 is what would be sent back for the LMS to display.Do you have more than 1 test in your title? It sounds like their are two tests and you only took one of them. With SCORM, it always bases the score of all the tests out of 100 so if you got an 80% on one test and nothing on the second, a value of 40 is what would be sent back for the LMS to display.
