Audio events questions
Your audio files do not have to be in Flash format for the events to work. If you are publishing to HTML and have a Done Playing action, then it does need to be FLV.
I'm curious, what did you use to get the events in your audio file? I use Windows Media Encoder which only outputs to wma format. I chose to covert it to Flash anyway because there tend to be fewer issues with FLV audio.
