Using actions
This may be a rudimentary question, but can you confirm that the action is a child of the page itself and not the child of the text box? I've seen some instances where someone places a page action on an object instead. If you did indeed place the action on the text box, then it would not show.
With the action being a child of the page, you tell Lectora that when the page shows, then to show the text box after 2 seconds. I'm not sure if you are doing that or not.
Alternatively, you could also set an action on the page to trigger on a timer of 2 seconds.
If you still can't get it to work, could you upload a copy of the title to the Files section and tell us what it's called?
Kevin
