Variable not working issue
When you post, please provide enough information so we can help you. Please provide this info which might help. Not sure yet.1. What is the name of your test? (I assume you mean test instead of assessment as Lectora does not have something called "assessment")2. What is the name of the variable you are using?3. Are you using random test option? If you aren't, what actions do you have on the very last button before you get to the Results page?4. What options to you have checked on the Results tab and the When Completed and When Passed tabs in the Test properties? 5. When you check the Show test results to student, does it show the questions correctly answered?6. What version of Lectora (2005,6,7)?
