Variable not working issue
I've had the exact same issue before - copied a test over, then the test results page wouldn't work, just as you described. I'm guessing that the test in the new title is not named the same as the copied test? At least, that's been the cause of my problems if I remember right. I believe I fixed the problem by looking through my actions and correcting the variable names to use the new test name. Something to try is to create a new test in the same title, add a couple of fake questions, then attach the results page to the new test. If the score is working right then that should give you some hints on what to fix.Russ
