Test Problems (part 2)
July 25, 2008 12:00 AM
Hi,I'm running Lectora 07, SP5. Testing in IE6 and Firefox 2.I have a 10 (multiple choice) question test, with custom test results set (no popup).I am showing the user the questions missed and the answers they chose.Often, but not always, the "ok" and "print" buttons are way the heck down the screen with big gaps in between the questions/incorrect answers.Often, but not always, the "ok" button doesn't do anything (it should take the user to a success or try again page).Often, but not always, theres seems to be a java applet problem when "ok" is clicked. I get an error in IE, something to do with Java runtime, but I don't get the error each time.Some users I've had test it have the same problems above--but then some don't. Makes it quite difficult to troubleshoot.Any ideas?Thanks!
