variable help
February 21, 2008 12:00 AM
Add actions to display 1starVAR just before you test it and after a couple of the Add to Variable actions. See if it has the proper value. Add actions to display 1starVAR just before you test it and after a couple of the Add to Variable actions. See if it has the proper value.
