variable help
February 21, 2008 12:00 AM
Probably the best way to manage the stars. Diane's approach is probably the best for you right now. You could do it with one variable that you added a different letter for each star. Then in the test Diane described instead of testing each variable for 1, have 10 conditions that check for:variableX Contains avariableX Contains betc
