variable help
Hi James,Try this: Create a separate variable for each item or star, eg., AstarVAR,BstarVAR, etc. Add an action to each office item to modify the appropriate variable on mouseclick.Add an Action on the page to Show the hidden "continue" button. On the Conditions tab, specify "multiple conditions." Choose each of the 10 variables, and set values to "greater than or equal to" and "1." Make sure to specify that "All Conditions" are met, not "Any Conditions."It's not too elegant but pretty straight forward. Hope it helps.Diane
