Test Problems (part 2)
Hi,Not sure about the various intermittent errors you are getting but might be able to help with the position of the OK and Print buttons. Looking at the default page they are part of the footer group and have offsets set from the right and bottom of the page.As you are showing only the questions missed the page leaves a gap for each question answered correctly - hence all the white space.I solved this by moving the buttons into the header group.Not ideal but to my mind a bit better.hope this helpsAndy
