Setting Lectora Default fonts.
Hi,Is there a way to set the default font for intital text blocks? Similarly, when you add a test question, is there a way to set the default font for the question text and answers as well? Thanks.
Discussion (1)
You can set the default font type, size, color for the entire title by going into the background tab in the title properties. It can also be set at the chapter/section/page level as well. This title can then be saved as a template. Use the template when creating new titles and that way it will already be set for you. You can set the default font type, size, color for the entire title by going into the background tab in the title properties. It can also be set at the chapter/section/page level as well. This title can then be saved as a template. Use the template when creating new titles and that way it will already be set for you.
