FireFox java problems - courses freeze
Look at the way the LMS is launching the content. We have seen numerous times that the window that actually launches the content sits on an interval timer to check when the content goes away. When it does, the window updates the LMS and then cancels the interval timer. This is backwards, the interval timer MUST be cleared before trying to update the LMS ... otherwise, you can get into an infinite loop where the interval timer keeps firing off if the update to the LMS hasn't completed. Different browsers/JVMs will illustrate the problem in different configs because it's a timing issue.Tim
