Question Won't Display in Saba LMS
This is really simple: publish my title using v10 is fine. Publish my title using v11 = I can't see the question! The question is a multiple choice question -- I see it in ReviewLink, I see it published as HTML, but when mounted to Saba LMS, I can't see it. Please help!
PS - Every other page without the question object is fine.
Discussion (7)
When you compile especially for SCORM do you have a checkmark for "Report test/survey question interaction to the LMS" checked?
Yes I have that checked. Also tried both "Append timestamp to interaction to create unique ID" checked & unchecked with no success.
Hi Wee,
For Lectora 11, if you go to the Test's Properties, under Results, there should be an option for "Include ALL Variable Values". For some of the courses that I created in Lectora X.6, that field is defaulted to no checkmark.
I believe, if you first put a checkmark in the "Custom Results Submissions", it will then let you be able to put a checkmark for the "Include ALL Variable values".
Hope this helps.
-kelly
@Wee 56747 wrote:
Kelly - Lectora just told me to upgrade to v11.2a and it fixed the issue. Thank you so much for helping me out.
Most welcome. Saw your posting in the Saba group about the content player for mobile learning. That group seems to be very slow. Please do let me know what you come up with, as I'll be interested too.
Thanks,
kelly
Thanks again Kelly. Problem is -- it's not a test, it's a question in a page :( and I don't see that option in the question properties.
Hi Wee,
To my knowledge, individual questions should not make their way over to the "History/Responses" section of Saba's user interface. The only items there should be testing questions that were marked to be interacted with the LMS.
Perhaps testing with the SCORM Cloud, with a freebie account to see if it reacts the same as your Saba system.
-kelly
