Question Reset Loop Issue
January 16, 2015 12:00 AM
I have created a Drag-n-Drop question with 2 attempts. Action Groups are setup for the feedback. After answering the question incorrectly the question is reset (using the Reset Question option), but after the attempts are complete the Final feedback group doesn't appear...it just continues to loop to resetting the question.
My guess is there is something wrong with my group or I shouldn't use the reset question option, but i'm not sure.
Any ideas?
Thanks
