Problem with Lectora/FrontPage
May 12, 2008 12:00 AM
So when you go to the directory where the Lectora page is, if you double click on it, it will display just as it should but when you attempt to launch it through your other application, it doesn't. Is that a correct statement?So when you go to the directory where the Lectora page is, if you double click on it, it will display just as it should but when you attempt to launch it through your other application, it doesn't. Is that a correct statement?
