Problem with Lectora/FrontPage
May 12, 2008 12:00 AM
Since it displays fine outside of the FP page, then the Lectora content is fine. It seems that for some reason, the way FP is launching the page, it is causing a JavaScript error on the Lectora page. If you would like to send me the files as a zip file to support@trivantis.com with the subject line For Ed, I will take a look at it and see if I can determine what is causing the JS error on the page.Since it displays fine outside of the FP page, then the Lectora content is fine. It seems that for some reason, the way FP is launching the page, it is causing a JavaScript error on the Lectora page. If you would like to send me the files as a zip file to support@trivantis.com with the subject line For Ed, I will take a look at it and see if I can determine what is causing the JS error on the page.
