Need help with cgi txt file ormat
I POST it to a cgi server using:http://www.
/cgi-bin/cgiemail/test.txtand the code in my first post is in the test.txt file.The cgi server sends me an email with the fields in brackets filled in with info from the application (Lectora)My problem may not be the cgi at all since the following became apparent after I published to html rather than exe. I have 2 pages in the quiz with a few questions on each page. Page 2 takes 36 seconds to load?!?!?! Then the results box takes 6-8 secs to load. Then I get a javascript errorbox which says "Security error . Cannot send results. Access denied. (SocketPermission www.jcu.edu.au:80 connect,resolve) Is this a server issue that has nothing to do with Lectora or not?
